plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Unread July 10th, 2019, 07:01 AM   #1
putiss
Czech_Republic
putiss is offline
S7-1500 Wrong partner port
Hi all,
I have an issue with S7-1512C cpu. Cpu has error Error on partner - Wrong partner port. Project has 1cpu, 1hmi and some tcp connection. Profinet tpology is not defined. DO you have some tips please?
Thanks in advance
Unread July 10th, 2019, 07:28 AM   #2
cardosocea
United Kingdom
cardosocea is offline
Did you define that the HMI would be connected on that port or the other one?
Unread July 10th, 2019, 08:07 AM   #3
BryanG
United Kingdom
BryanG is offline
Are you sure there is nothing in Topology View. Only seen this error when something was defined in Topology View, ended up having to add a dummy Ethernet Switch.
__________________
Knowledge is power, share the knowledge.
Unread July 11th, 2019, 06:21 AM   #4
putiss
Czech_Republic
putiss is offline
Topology view is without connections. Switches are non siemens - could it be this problem?
Unread July 11th, 2019, 06:33 AM   #5
sigmadelta
Canada
sigmadelta is offline
Create a new project and upload from the CPU, and check if there is a topology.
__________________
Automation Programmer
PLC / HMI / SCADA / SQL
New Systems, Modifications
System Upgrades & Conversions
Visit: contrologica.com
Email: info@contrologica.com
Unread July 11th, 2019, 07:43 AM   #6
BryanG
United Kingdom
BryanG is offline
Unless it is a big project, maybe backup the project and then create the correct topology. I guess you would use unmanaged Siemens Switches to simulate the non-Siemens stuff. Sorry I can not be much help, not a lot of experience with this stuff.
__________________
Unread July 11th, 2019, 07:49 AM   #7
putiss
Czech_Republic
putiss is offline
Yes I use some siemens switch to check it...
here is a topology from upload
https://pasteboard.co/IntZN0D.jpg
Unread July 11th, 2019, 08:08 AM   #8
BryanG
United Kingdom
BryanG is offline
If you right click the PLC in Topology View and then choose Port Interconnection, is anything shown in the Partner port?
__________________
Unread July 30th, 2019, 01:48 AM   #9
putiss
Czech_Republic
putiss is offline
Solved!
I defined profinet topology between plc and hmi to P2 port of cpu and added new direct cable between cpu and hmi.
Thank you all !
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
S7 1500 Hardware Assembly iadapt LIVE PLC Questions And Answers 1 October 12th, 2016 04:04 PM
Upgrade PV600 (RS-232-DH485) comm. to ML1500 to PV+ nicer LIVE PLC Questions And Answers 35 July 1st, 2015 05:05 AM
Micrologix 1500 Serial Port SEBP LIVE PLC Questions And Answers 10 April 17th, 2015 02:27 PM
s7 1500 cant connect to wincc scada Blue Fox LIVE PLC Questions And Answers 1 October 3rd, 2013 06:32 AM
PG to S7 300 via MPI port omarrosa LIVE PLC Questions And Answers 12 May 4th, 2004 12:06 PM
