Hi guys!
In my current project. I'm using a CompactLogix 1769-L32E and an HMI panel called Etop507. Due to distance requirements i have to use DH485 between CompactLogix PLC and the HMI panel.
The HMI panel has a RS232, 2 USB and 2 Ethernet port.
I have connected the Channel 0 of the PLC to RS232(port 2) of a 1761-NET-AIC+ and i use port 3(the DH485 port) of the 1761-net-aic to connect to the RS232 of the HMI panel.
I have configured the HMI panel to DH485 and the PLCs Channel 0 to DH485.
The HMI panel software JMobile suite supports DH485 and tags can be defined using SLC500 type addresses. I used the "SLC500 data mapping" facility under logic in RSLogix5000 to map a simple INT array.
I wrote few test MSG instruction in RSLogix5000 to send a data block using CIP data table write...but when it comes to "node id" i can't figure it out
I appreciate if anyone can help
