PanelMate Configuration Export
allanb76
Dec 2018
Nanaimo
Hi there. We still have a few old PanelMate Power Pro 1700's kicking around that I should upgrade, but haven't found the time yet. I need to make a few minor changes to one but am having troubles. I've been able to open the database and modify the screens no problem. When I go to export, a dialog box pops up saying " There is no window register entry for this operation. Please run register file and register it again"
Am I missing something simple? Has anyone seen this before? Is something corrupted with the software? I hope not as one of my former employees seems to have walked off with the disc.
It sounds like you will either have to reinstall the software or else manually edit the registry. The problem with manually editing the registry is knowing what you will need to manually enter.
Your best bet is probably to contact these folks:
http://info.atsonlinestore.com/html/panelmate_information.html
I don't see a free download of the software, but maybe they can help.
Edit: If your changes are simple enough, send me a private message through this site. I'll give you my email address. You can send me your most recent exported file and a description of the changes. I can import, make the changes, export, and send you the result. I don't mind spending up to a half hour or so to do it.
Hello all, I hope there are some PanelMate aficionados in here. I have a pretty simple question that Cutler-Hammer doesn't seem to be able to...
2,686
We have an old Panelmate 12" 7685T HMI that went out and we are trying to replace it with a Panelmate 7685T-8C (classic) that we had in the store...
2,392
Hi people, Hoping someone can help me. I have been tasked with adding some screens to an existing panelmate running in the middle of nowhere. I...
4,000
I am attempting to download a configuration to a 30 page Panelmate Plus Compact. I am using Panelmate configuration software version 1.14. I...
12,020
S
I'm searching the configuration software for a Panelmate 1000. I have to do one little modification in an operator interface Cutler-Hammer...
8,041
