Citect Siemens S7 tag addresses ?
PLCKeef
Nov 2005
Australia
68
Hi all
finally got around to connecting Citect to our new S7 PLC's , just having a little trouble with fiding the correct way to address a tag.
In the old S5 PLC's I use to address a Data block "D010:001" thta would give me data block 10 and data word 1.
Or for a particular bit I would do D010:002.01 which would give me Data block 10 , data word 2 , bit 1.
So for S7 , how would I do it ?
I was workign on it last night , but ran out of time , the comms are working now and can directly access I/O's , but couldn't get the right addresses for my data blocks.
The PSdirect drivers work well using just the MPI cable , bugger siemens and their expensive cards :)
Addressing S7 using Citects S7NT driver
I use S7-400 PLC's with Citect.
I use Profibus and CP5613 (A2) cards.
I use Citects S7NT driver.
I always get data from Data Blocks.
Examples:
TYPE ADDRESS
DIGITAL DB1,28.3
INT DB1,26
REAL DB200,8
LONG DB200,48
However, using the PSDirect drivers your addressing is likely
to need to be different.
I am interested in saving the cost of the Siemens CP cards.
What do you order from PSDirect and what does it cost?
Thanks John
I am using the demo version of PSdirect , it will run for 2 hours , and citect for 15min , so that is plenty for testing student projects.
I think I tried some of the combos you have above , apparently the addressing is the same as using the usual S7 addresses , it worked fine for input bits , so will have another go.
thanks for the help.
I have a simatic S7-200 smart PLC with SR20 CPU and ethernet port. I would like to interface it with my Vijeo citect 7.4. it would be really...
1,172
I need to know the steps to communicate Citect 2016 with Siemens S7 1500 using S7TCP driver. Thanks
27
17,839
hi how can i Communication between Siemens S7-300 and Vijeo Citect 7.2 with Ethernet tcp/ip ? please help me!🤞🏻🤞🏻
1,769
Hi, I have a plant with 400 CPU and a HMI system from Scada (7.20). I want to let the 400 cpu sync against Citect. Citect already time sync...
1,809
I'm wondering if anyone has any insight into Siemens communications and may be able to help me with a communications problem I'm having? I have a...
4,189
