FP-X, FPWIN, Pulse Output
pfournier
Jun 2008
Rhode Island
I am new to the PLC world. Though ladder diagrams are not new to me, the last time I did them I used real 115V hard wired relays.
Our only PLC designer left for another job and I inherited it. Ive done everything from circuit design to programming in assemebly, basic, fortran and C and I do VHDL on ocassion, but this stuff is totally different with a language all its own and I am not finding it real intuitive.
Enough of the whining, let me get to the point.
The original design was done on an FP1 C14TD and I had to translate it to an FP-X C14TD. All this does is wait for a switch closure, run a stepper motor at a constant speed and pulse an output at a selected duty cycle.
The biggest change was the pulse output which on the FP1 was the "F164 SPD0". I had to change that to a "F172 PLSH". It compiled fine and loaded OK but when I went to switch to "RUN" mode I get the error in the Status Display "[45] Operation Error Occured". I have looked at the help in FPWIN GR and I went to the Panasonic site and read the FAQs there. I have found nothing useful.
If anyone has any ideas I would appreciate it.
If necessay I will try and reproduce the ladder diagram here (looks painful to do), or perhps there is a place here to put an ".fp" file.
Thanks,
-Pete
Hi.....
a few years ago I got the same problem.
1. are you have changed y0 (k0) be out pulse? ( in configuration plc )
2. if still error, try to turn off the power source plc, for a few seconds.
after that error will disappear.
and you can connect back to your pc
I hope it can help.
sorry for my english writing is bad
I'm writing some alterations to an FPWin program and need to see the running value of timers so I can set them correctly. It's my first time with...
131
Can someone tell me what I'm seeing here? I'm online with the FP2 and looking at some rungs with DT120 and DT124. Each are used twice and each...
1,732
YIKES!! I have done most of my training in RSlogix and making a retentive timer has never been a problem. I recently took a job converting...
2,069
I have been working on an existing project for some time now and restructured the whole program into POUs instead of a singular main. Everything...
18
3,215
I have an older (2006) Panasonic FP-X C14R that i need to connect to. I have zero experience with Panasonic PLC's and the FPWIN Pro7 software...
2,316
