I should have been a clearier. I know which channel is DH+ and which is RIO, but this cabinet is about 300 yards from the PLC cabinet and there is mulitible termination box for the (blue hose) some of which go up to the ASB and just come in the cabinet and go back out. I am thinking the ones that go in and out are DH+ because i wouldn't see much reason for them to be there if they were RIO.
I was wondering if there was a way to be sure that this was DH+ or Remote I/O electronicly ie... voltage/amps. I havent' had alot of dealings with DH+ so i am not realy sure of the specs.
Let us be quite clear about this - there is NO electrical difference between DH+ and RIO networks. They both use the same cable system (let's ignore the cable covering colour for now), and the same transceiver chips in the nodes. They both support up to 64 nodes, and both can be "daisy-chained", as you'd expect because the network physical transport layer is identical.
The
only thing that makes the networks "different" is the language, or protocol, that the nodes use to communicate with each other.
So what makes the networks "different", is the devices that communicate on them, i.e.
how they talk.
As far as I know, there isn't any hardware that uses both DH+
and RIO protocols simultaneously, but there are devices that can use DH+
or RIO by configuration.
As for the cable colour-coding, it was a specification laid down by Allen-Bradley that RIO was 1-clear, 3-blue, and the opposite for DH+ --- or was it the other way round
