Publish InTouch 10 to information server 3.0 - communication issues
NFischer1978
Sep 2008
California
16
I have a small problem with publishing an InTouch 10 application to the information server from wonderware. The data I want to display comes from an historian at one of our plants. I am able to connect to this server and I will see the data when I go online with the InTouch application. The access name there is:
Node: Computer name
Application: servermain
Topic: Topic name
Protocol: SuiteLink
I convert the InTouch screen with the WinXMLExporter and set the WindowSet properties to the same values. Unfortuantely I can not see the data on the information server. Has anyone an idea why that is? I can see the InTouch screen, but it won't get the data from the IO server.
OK, I changed the reference to the running InTouch program on my PC and it will work that way, but I would prefer to reference directly to the I/O server. Otherwise I need to let the application run on my PC.
Working configuration:
Node: My computer name
Application: view
Topic: TagName
Not working:
Node: Server name
Topic: TagName
Hello Everyone, I work for a company who builds a machine for the automotive industry. Recently, we build a new line at the plant but the line...
4,202
I am currently working on converting an Object-based ArchestrA System Platform HMI to a Tag-based InTouch HMI. Currently, the I/O is linked...
20
I have a problem, I'm running an AE Licence Manager on a Windows 2016 Server, and my Window Maker is on another separate Windows 2016 Server. My...
87
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
256
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
144
