Looking for a variable speed control for single phase motor(s)
MikeVT
May 2008
Holland, MI
83
Does anybody have any experience/suggestions for variable speed control of single phase motors?
My application is: Control up to 4 - 1/2hp fans (shaded pole motors), via analog output from a PLC.
Additional details: My thought is possibly 1 'drive', with separate overload protection for each motor, if needed, controlled by one common analog output.
I know... 3 phase motors wold be much easier. That's not possible in my application.
Thanks for your help.
Thanks James.
All I can find with AB is single phase in, 3 phase out. (PowerFlex 4).
I did find a hit via google, for Invertek. I could get a 1hp unit, and feed 2 fans per drive. Anybody know anything about Invertek drives?
You can many of the AB drives single phase (even though listed as a 3 phase motor). Contact your AB distributor, they will definitely have a tech. that can help.
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/26098
https://rockwellautomation.custhelp.com/app/answers/detail/a_id/516312
If you don't have a TechConnect contract, all of the PowerFlex Technical Data manuals have the single-phase ratings. The few I have come across in the past were basically re-rating for 50% - 65% over.
It's amazing that whenever someone raises this question, so many people misinterpret what the OP is trying to accomplish and post links to VFDs that can produce a three-phase output from a single phase supply. Too bad that's not what MikeVT needs.
In my post #3 I linked to Anacon Systems Eagle Drive that the datasheet clearly states:
Series # 1S covers six(6) ratings in the power range of 1/6HP to 3/4
HP, all suitable for 115 volts, single-phase input, with 115 volts, single-phase output.
How is that NOT what the OP requested?
Sorry about that, seem the remember we used these drives for single phase machines, I must be wrong..
AB PowerFlex525 go all the way down to 120vac single phase. I just bought one for a project. Part number 25B-V2P5N104. Also has built in Ethernet.
The original poster did mention shaded pole. The invertek units will work with most shaded pole designs. The last time I checked the prices on the invertek units, I decided that it would be much more cost efficient to change to 3 phase motors.
That said there is this thread from 2005 when Ron Doran was alive, discussing this problem. http://www.plctalk.net/qanda/showthread.php?p=200316#post200316 . In post #36 http://www.plctalk.net/qanda/showpost.php?p=200316&postcount=36 a PLCs member claims to have made a single phase motor with a start switch function on a three phase output VFD. Note: he used a solid state relay to avoid an arc at the output leads of the VFD. If it did function, I'm sure that the low speed performance would be very poor.
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
126
I have Allen Bradley plcs, I have had Circuit breakers and other automation equipment in the past. There's no solid buyers local. How much do you...
193
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
137
I want to monitor a couple signals in a place where there is no PLC but there is ethernet. I know I can use an AENTR or Flex I/O and a module but...
21
740
I downloaded v24 for studio 5000 but can’t find where the download manager put it! Any help? I’ve done it before but can’t remember. Thanks
378
