I've just been give a task of controlling a bul. 160 ssc controller with a AB plc/5. I've never done anything like this before. I need to ramp the motor up based on the encoder output the higher the encoder count the higher the speed of the motor and vice versa.I will be using an analog card to give the motor a 4-20 ma signal.My question is how can I control the output signal to the motor and what kind of command set should I use? and where could I find a sample program to control a vfd? I have used a Mitsubishi plc FX1S-14-MT and use the high speed pulse output to control a servo drive, but I have never used an AB plc to do motion control. Any help would be very much appreciated.
Thanxs in advance
Lab
Thanxs in advance
Lab
