Looking for a replacement for my preferred DIN 35 rail b
sparkyinak
May 2016
Ketchikan, AK
79
I found out today that the 35mm DIN rail I wanted to use for a project is obsolete. The DIN rail in question is the Schneider Electric (Square D) AM1DP200. Instead of perforated longgatec slots, there are 1/4" round holes at about 1" on center. Is anyone familiar with another similar brand of DIN rail out there?
Or order DIN rails without holes.
The person who is going to install the DIN rail is going to drill holes in the mounting plate anyway, so it is not much effort to also drill the holes in the DIN rail.
Thanx all. especially the duct tape idea. I was asked to find a replacement by the powers that be. Had something to do with grounding/bonding due to the terminal blocks that's being used. They ground directly to the DIN rail. Engineers and bean counters. Go figure
Hi , Where i can find Mitsubishi PLC Card end of line & replacement model details. i am looking for Q02CPU replacement model. Please advice. thanks
126
Im looking to replace a retroreflective Photoeye with a throughbeam or light curtain. The retroreflective eye is causing some issues with...
4,093
Long time lurker, first time poster. I am looking to see if anyone can recommend an inexpensive IPC. We are currently using the Proface...
2,650
Hi all. We have a duetchmann cam controller locon 32 that the keypad is bad, cant get parts or a new locon 32 since it is obsolete after the RoHS...
1,759
I replaced one of these about two years ago and I can't find the pdf that stepped me through the countless layers to get to the fan. Anybody got a...
4,082
