CompactLogix 1769-L30ER Vs. YASKAWA MP3300 Connection Problem
hungwei
Jul 2018
Tainan
Hi All~
I have a case (designed by my boss But he has left the company)
Please refer to the attached picture
https://photos.app.goo.gl/B5p644LUx65B6tkj9
CompactLogix 1769-L30ER(Master)→EtherNet/IP→YASKAWA MP3300→MachatroLink→YASKAWA Motor (4~6 axis)
Send:Servo Position、Speed、Cantrol Commands
Receive:Servo Position、Speed
Is this design feasible?
first,How should I do it?
Does anyone have an example?
If we don't use this architecture(don't use YASKAWA MP3300)
Can we use the AB PLC to directly control the 4~6 axis absolute servo through communication?
Which kind of PLC and module to use?
I'm still pretty new to AB PLC programming
Welcome to the forum.
I was also proposed to use MP3300 as a 'slave' to a compactlogix. I spent 2 days looking through Yaskawa manuals before I made the decisision it was not possible. Maybe it is, but if so I didn't find out how.
Going forward, if you are in america you can buy the sigma compact 7 and use AOP.
Outside america use https://www.yaskawa.com/products/mo...6-8fc1-4a66-875f-fbf64073d4f3_Models38Ratings and change the firmware and it will behave like the compact version.
https://www.youtube.com/playlist?list=PLNAENlyEDCkwyKty6WKoekdBmELwBniQ9
I have downloaded the AOP and installed ok, now I am waiting for the rest of my hardware.
Good luck!
The MP3300iec can certainly be controlled via Ethernet/IP, but you will need to make a custom application program in the 3300iec. Depending on what you want to do, using a version of the SigmaLogix drive will be easier. At that point, the Yaskawa drive essentially looks like a Rockwell drive to the PLC.
What he said.
Thank you all~
Dear the_msp:
sigma compact 7 not sold in Taiwan
so.....Still using mp3300
Dear Highland Controls:
We using mp3300 not mp3300iec
Using:
Power Supply & Base Unit Rack:JEPMC-BU3304-E MBU-304
MP3300 Machine Controller CPU Module:JAPMC-CP3301-1-E CPU-301 (16 axes)
EtherNet/IP Communication Module:JAPMC-CM2304-E 263IF-01
Now I download yaskawa MP2000 - EtherNet/IP EDS File
can not add new module in rslogix5000
"at least one connection must be configured for this device"
Images:
https://drive.google.com/open?id=1bEz1YNAN6qYgG5GknA84uptEP6N2WOVI
EDS file:
https://drive.google.com/open?id=1qlCCrTpJyAJVOYhGqT6z0IxBrrmfe3XC
Hello Friends I need to replace a Micrologix 1400 L32BWA with 1 1762-OB16. I had thought in a 1769-L30ER, 1 1769-IQ32 and 2 1769-OW16. But...
2,400
Hi guys. I have some problem.I want to use AB PLC Control YASKAWA servo motor through MP3300 EtherNet/IP Communication Module. Now I download...
2,135
Hi, I am Akash. I am currently working on a PLC upgrade project from micrologix 1500 type to compactlogix 1769LRP. I have migrated the whole...
5,406
Hello, I am having some issues telling my ASCII card to send out data. Right now I am using a Serial-USB and using hyper terminal to receive the...
2,195
Does the CompactLogix 1769-L30ER use a battery for memory backup or does it have internal flash memory?
9,833
