Help!) I wonder in S5
Bandy
Jun 2019
Seoul
18
Hello again~
I have a question in S5
When Converting it, There was an error occured in FB221 .
So I tried to find the error , and I finally found . The error MSG is in the picture
FB221 seems too long to store STL, so I want to share it.
(ex Making FB221 ,FB223 and the end of FB221 writing JU FB223)
Is it possible..? , Is there any problem to use..?
FB221 is a Siemens Library function (TD2:MELD), you cannot use it in S7.
Ah..? Can't we use the FB221 in S7??
Then.. How can I see the FB221 in PG-2000 (S5)
The error code said 'That's too long to save' ....
I don't know how can I solve this problem
The "TD2" library blocks usually mean that there is a text display in use.
AH!!! I really appreciated with you!!
Can I ask something when I have a problem later ?
Using the SNS (ex kakaotalk or line )
I'll contact you, if you could give me your ID,
The standard blocks are often more than 255 steps long without segments so will not convert into S7 and probably will not work anyway, Siemens put a JU=M001 in first segment and a Block End so it will not display (their protection). Is there an older type HMI on the machine you are trying to convert ? also even though other standard blocks may be used these often cannot be converted so you will have to replace them with an equivalent or roll your own. I have tried a number of conversions and to be honest most of them caused more problems and took longer to sort than starting from scratch.
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
97
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
106
Hello, I need to write the following program in Ladder language, but I could not integrate the Fibonacci sequence into the ladder. Can you help...
22
470
this a program to send data to barcode printer I want to integrate a new printer in a new machine and i wanted to adapt the old prgram on it but I...
175
67
