Is it possible to dynamically change the Motion Polarity in the program?
Nov 2013
Michigan
532
This is a CompactLogix L33ERM, version 30 (31 is too unstable on my machine to work with), with a Kinetix 5500 drive.
I have a program where there are "Right Handed" and "Left Handed" oriented parts and there is a rotary twist that is essentially mirrored between the two programs. If I could just change the motion polarity in the program based on what kind of part I'm running, that would make my programming a LOT simpler. But I can't find anything online that says yes or no.
EDIT: I found I can use the SSV to send that value, but I'm not sure if it will actually work.
Or have two different motion commands, except each is enabled and triggered based on the desired polarity. Thats probably what I would do, it documents well with nothing fancy to confuse someone following my work.
Hello All, I need the ability to remotely reboot a Red Lion CR3000 HMI. Due to some graphics issues when the database is updated the HMI must be...
218
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
344
Folks, I have a client with an old ABB Advant / MOD300 system (v14.4). Around y2k I installed the ABB Industrial IT MOD300 OPC Server 1.1/2...
178
Hi all so i have a robot project im working on were i need to set the layers. using the hmi screen i would like to use the numeric data display to...
818
I have a FactoryTalk View Se project, Is it possible to export Direct Reference tags to edit in a CSV file or Excel? I know I can export HMI...
288
