Intouch 11.1 Licencing & Ethernet port Relation
BabluRout007
Nov 2017
Chealse
Hi Everyone ,
If anybody have any Idea between Intouch license detection & Ethernet port relation ?
I am working with an Intouch panel PC contains 2 ethernet port.When I am disabling port no. 2 , intouch cant detect the License.
Idea?
Is the license remote or local?
If it is remote..then the license detection may have a problem with the Enet connection disabled.
If license is local..then there should not be a problem with Enet.
When you go to Start>All Programs>Wonderware>Common> "ArchestrA License Manager"...what is the "License Path"?
Some license servers will bind to the MAC address of a network card. Usually you can tell by looking at the host information. You may be able to rehome the license w/ some help from Wonderware over to the primary NIC.
Sounds like you have a runtime license that is keyed to the hardware, I used to have a couple like that, we were able to get the license upgraded to a software key for a fee.
Look in the text of the license file and it should tell you if it is keyed to the hardware.
Hi all. Customer wants analog faceplates really bad, even if we explained that it doesn't make much sense in his process. What he wants to see...
108
Trying to export a Modern application for an upgrade to Intouch 2020 but I cannot export the application from the 2014 version because the export...
103
137
Currently we have a fat( I think that is what it is called) Intouch application. An application resolution of 3840x1080, and inside that 2x...
89
Hi guys We're in the process of creating a ME runtime to operate on a PC running windows using a InTouch INDT156 touchscreen, and we're having an...
140
