Mean Well PS
CaspianSage
Jan 2017
Where I Am
128
Do any of you have any experience with Mean Well power supplies?
I am looking for some low cost 5, 12 and 24 VDC din rail mt.
For the 5, I need 140mA MIN, but want up to 3amps at 5V dc +0.25V with less than 50mV ripple, peak-to-peak.
just wondered if these are sufficient for not critical application in a clean environment an reasonably clean power source or if i should look elsewhere
Thank you!
I have used several of the 24vdc models and a few of the 12vdc models with zero problems. Never had a requirement for 5vdc.
My former employer began specifying them in their projects the last year or two I was there. No known issues with them and the price was definitely attractive.
Mean Well is good stuff - also for critical applications.
They have several series of DIN rail mount power supplies so pick the one you need. I usually pick a better one than I need because the price difference is small.
Thanks for taking time to reply everybody. I was really surprised to see these at such a low cost so I was cautious and figured someone here could tell me if they are any good.
I used to use SOLA for most applications. If I remember correctly they are a lot more expensive.
Wow...
These are considerably lower than the Phoenix Contact "Quint" I have been using...
I wonder how they compare?
Quint is Phoenix Contact’s top of the line power supply.
I think the low cost Meanwell supplies are more like the Phoenix contact Uno power supplies in specs and cost.
The picture attached relates to the properties for the F9 key. Does anyone know what 'object number' refers to? What does 'object number' mean...
708
I have used plenty of Fx 3U's but this is the first I have ever seen the ES-A. I can't find any refrence to it in any Mitsubishi literature. Looks...
2,291
When I do a search of used devices (typically, to find a spare one I can use), this table appears, but I don't understand what "unpaired" means or...
1,374
When I press F4 to convert the code, I get this message. What does it mean? Thanks
2,540
