Get activation key with different serial number
mulderm
Jun 2003
Netherlands
298
Hello,
I have a masterdisk with a serial number without a key
installed.
Now I have on my Laptop installed AI-series PLC-5 with
an activation key and a different serial number.
Problem is that I have not the master-disk for this so I
tried to get the activation key with the masterdisk with
the different serial number.
Now I get the error message: "Activation File Corrupt -
Invalid serial number".
Is there another possibility to get the activation key
on my masterdisk with different serial number?
Greetings,
mulderm
You have two options:
1. If both copies of the software are in your name or company name, you can call up AB Tech suppport and let them know you have lost the master disk. They will send you out a new one as long as it is been a year since you last obtained one or asked for a reset from them.
2. You could also send a Fax to AB Tech support with the serial number of the master disk you have and the serial number of the software on your computer. They will then send you a new master disk. Most likely, they will want the original master disk you have sent back to them or they will charge you for software after 30 days. Again, the software copies have to be in your name.
Hope this helps,
Todd.
Hi guys; I have a image dvd of laptop when i install it the rslogix, rslink, rsnetwork are restore with activation. If i move this activation key...
5,282
I have a older version of RS logix 500 that will not work with windows vista nor the new 7..a friend of mine give me a copy of a newer version of...
11,278
Hi guys, Our customer has undergo a reinstatement for RSLogix 500, we've received a white envelop from Rockwell c/w a CD ROM, but when we need...
3,281
I had my copy of rs logics 500 on my laptop when it stopped working,I have had the hard drive contents loaded onto a external hard drive. I am...
1,908
Hi, I have laptop with no floppy drive (or external floppy) and need to load an RSView activation key onto the laptop. Right now the key is on a...
4,836
