Run 2 LS HMI's simultaneously from Mitsubishi PLC?
sawyer65
May 2016
Auburn,AL
21
I am trying to set up 2 LS HMI's to run simultaneously from a Mitsubishi PLC over Ethernet.
PLC is a Q10UDEHCPU set to ip 192.168.0 10
HMI 1 is LS XP70 set to ip 192.168.0 2
HMI 2 is LS XP30 set to ip 192.168.0 20
In the open setting page of the built-in ethernet port tab of the PLC parameters in Gx Developer
1st row is Protocol=TCP Open System=MC Protocol Host Station=0402
2nd row is Protocol=TCP Open System=MC Protocol Host Station=0403
On the HMI side:
Under the controller settings of XP Builder.
Maker=Mitsubishi Electric Corporation Product=Mitsubishi Melsec-QnU CPU (Ethernet)
Connection Protocol=Ethernet
Under detailed settings:
I have the XP70 set to ip 192.168.0.2,destination port 1024,local port 0
I have the XP30 set to ip 192.168.0.20,destination port 1025,local port 0
I cannot get them to run simultaneously, one will always have a PLC timeout error. If I unplug the Ethernet cable from the one that is running, the error will disappear from the other one and it will start running so I am sure my cabling is correct. All three are plugged into a 4 port switch.
Is there a setting I am missing somewhere?
Hello. I am new with PLCs, and I am working on modifying code for a non-production system with no safety implications. We are using an...
2,301
Good Morning , I have an application that I need to increase and decrease the FPM on conveyors . I have a HMI PB for increase and decrease...
26
5,127
Hi, I need to intercept the Shutdown action in my Factory Talk 7.00 HMI using Studio5000 21.03 ladder logic, so that I can ensure all power is...
2,051
Good Afternoon , I have a FactoryTalk View application ( ME ), that I am able to "Test" Run the application on FactoryTalk View and it runs...
7,574
Hello, quick question about the Crimson HMI from Red Lion. I'm trying to learn the software and installing the Crimson 3.0 programming software...
2,700
