plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old April 26th, 2018, 10:14 PM   #1
JoeMTricker
United States
JoeMTricker is offline
Unity programming
I'm an electrical technician, so NOT a PLC/PAC expert. I work mostly with SLC's and Contrologix. Some of the old TI505 series. My son works somewhere else and is getting into Unity. He wants to know how to read from/write to another PLC on the network. Does anyone know the Unity equivalent to AB's produced/consumed?
Thanks in advance,
Joe T
Old April 29th, 2018, 04:30 AM   #2
msimango
South Africa
msimango is offline
works very different from the AB consume/produce there are comms blocks that are used in Unity under communication , you then configure the block to map data eg set IP add , starting reg to read and the total number to read and where to store the data that should get the data you need, they also have a scanner that you setup when using ModbusTCP is found on your communication card.
Old April 30th, 2018, 05:35 AM   #3
tragically1969
United Kingdom
tragically1969 is offline
Quote:
Thanks in advance,
Joe T
I presume when you say Unity you are referring to Schneider's programming package Unity Pro, yes ?
There is lots of option in the Schneider world for messaging but firstly have a read up on the IO Scanning service (this is depended on hardware though) and then READ_VAR, WRITE_VAR.
Old May 7th, 2018, 03:39 AM   #4
scrambled
Australia
scrambled is offline
scrambled's Avatar
Lol, OP is referring to a different Unity software, not Unity3D the gaming dev platform.
Cross-PLC comms on the Modicon platform is easiest done through Modbus TCP. As mentioned by others, you can set up I/O scanning service to do automated read/writes or you can do the comms within the logic itself using READ_VAR and WRITE_VAR function blocks. The latter is more work but will allow for more granular control over the nature of the data requests.
The above only needs to be done on the master delivering the read or write requests, the slave only needs to make sure the required data to be read from or written to is in the registers targeted by the master.
Old August 10th, 2018, 09:37 PM   #5
kwade
United States
kwade is offline
this thread went downhill quickly
Old August 11th, 2018, 06:13 AM   #6
geniusintraining
United States
geniusintraining is offline
geniusintraining's Avatar
Does not take them long.... but its cleaned up
__________________
www.PLCCable.com PLC Communication Cables, PLC Trainers, Fluke Meters, MicroLogix, ControlLogix, Siemens, Allen Bradley and more... all your automation needs... ((NEW)) After Market 1784-U2DHP Allen Bradley USB to DH+ and Gateways
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Schneider M340 And Magelis Hmi With Unlocated Variables Brendonh LIVE PLC Questions And Answers 16 November 13th, 2014 12:38 AM
Unity Pro with M340 P34 2020 (Forcing Analog Points, Simulator, ClearSCADA) Questions rnishimura LIVE PLC Questions And Answers 2 October 25th, 2014 01:44 PM
UNITY Pro PLC Programming with Modicon Premium Niwresh LIVE PLC Questions And Answers 8 September 24th, 2013 08:45 AM
Schneider - Unity Pro - Citect etc BobB LIVE PLC Questions And Answers 11 January 15th, 2010 04:13 PM
Unity PLC & FS GATEWAY shahid_iftikhar LIVE PLC Questions And Answers 2 September 12th, 2009 02:57 AM
