betamax
The hand held programmer works fine for backing and verifying up the program to tape (we use a mp3 recorder)on our GE series One CPU on one system.
On another system I typed in a program with the programmer and when I do the program syntax check it shows no error but when I try to do the tape backup the audio out is very weak. It is too weak to do the verify process. If I load in a known good program to the same CPU from tape backup I can record and verify it ok.
Does the weak audio backup from the typed in program indicate an issue with the program even though it doesn't show an error? What else should I look for to correct this?
