Micrologix 1400 PLC interface with LED Display for displaying the Loading Details
kali rajan
Aug 2016
Madurai-Tamil Nadu
18
Hai All,
In my application, the Micrologix 1400 for PLC and FactoryTalk View SE for SCADA Screens are used for Controlling and monitoring the Outward &
Inward loads for a Plant from 4 Conveyors. Also Displaying the Conveyor details of load for the Each loading conveyors. So, I need to interface the Micrologix 1400 with 4 LED Display. Is it Possible?...
The Main function are given below,
I Attached the Photo for this Application Please go through for any clarifications,
1) Sensor will count the Number of bags going through the truck loading conveyor
2) PLC will read the the sensor output and store the value in SCADA
3) SCADA Will generate the report for the individual truck (Truck number to be punched
manually in scada)
4) SCADA Should give the command to the operator through LED board what to load on the truck
loading conveyor
5) SCADA Should generate the report of inward and outward and stored stocks (inward will be
punched manually on shift basis through scada)
But I didn't know about that concept of LED Board for this application, so please suggest some ideas about the LED Boards and also please give any Model for the LED Boards...
Please send some ideas as soon as possible...
Please see the Attached photos for any clarifications in this application...
Thanks,
Kali Rajan M
+91 8015604415
[email protected]
https://www.automationdirect.com/adc/Overview/Catalog/HMI_(Human_Machine_Interface)/ViewMarq_LED_Message_Displays
ViewMarq LED Message Displays above will communicate both serial and Ethernet networks and can be connected to a PLC, PC, or any device capable of serial ASCII, Modbus RTU, or Modbus TCP communication.
Your PLC is capable of both serial ASCII and Modbus RTU communication. Here are some links for both options for the PLC.
http://www.plctalk.net/qanda/showthread.php?t=80543
http://www.plctalk.net/qanda/showthread.php?t=73953
Hope this helps you out.
Regards,
Need some Local Indian brand LED Board
Thanks for ur response,
Please Clarify this doubt, How to interface the 4 LED Board in a single Micrologix 1400 PLC... Please suggest some ideas to interface...
I already seen this ViewMarq product but its cost is too high for my clients. So they need any local brand for this LED Board and also available in India...
If anyone of know about the local brand pls inform me...
Thanks,
Kali Rajan.M
:huh: i don't know master password and i tried "1234" too but it didn't worked i want to upload new program but i think its password protected and...
978
Hi guys, Could i connect simatic WinCC runtime with Micrologix 1400 PLC via Modbus?
1,241
Hi guys, I'm chasing a strange one here and am trying to eliminate a far fetch theory I have. Background. I have a machine with 5 Micrologix...
2,338
Thought I'd post this to help other's out :) Any further questions, don't hesitate to ask. Credit to Keithkyll for his advice!, Using 24v power...
2,024
Hello everyone I have a problem of losing the ip address of the micrologix 1100 and 1400 PLC each time I lose power. the problem is that I...
1,752
