Wonderware Historian
Nov 2011
Ireland
182
Hello,
Can anyone give me some advice on how to configure wonderware historian. i have 4 analog signals that i want to store on wonderware historian.
is there any step by step guide on how to set up tags in the historian or some basic training video
regards
you configure the tags in the SMC (server management ceter). you expand down until you reach the topic servers. within the topic server you create a new topic, then an I/O server and then your tags.
depending on your OPC client you need to define a specific server .exe
what I/O interface are you using i.e. kepware etc?
Hi, We are setting up an Aveva Plant SCADA node with the intention to connect it to a Wonderware Historian node. Everywhere I look online I see...
164
So I'm trying to make a tag I created in WonderWare Historian display the correct tag values on the inTouch client but it is currently showing...
1,524
Hello there, Our plant is running Wonderware Historian on a Virtual Server and every few days I'm losing comms to my PLCs. Usually I can simply...
2,060
Hi all, I found some interesting issue from my Wonderware environment. At my Trend table option, if i select "both", the Trend table is not...
3,646
Hello, I want to monitor Wonderware historian's heartbeat and trigger a fault if Historian is not communicating /offline in PLC. Currently my...
788
