Accessing S5-135U PLC with HP laptop having WINDOWS XP Professional
RAJATPALLAV
Jul 2007
BHOPAL - INDIA
34
Dear ALL !!
I am trying to go ONLINE with S5-135U Siemens PLC using my HP laptop loaded with WINDOWS XP Professional using RS232 to TTY converter.
I am told WINDOWS XP Professional will occupy COM port on bootup itself so I cannot go ONLINE using COM port.
Is that correct? What is the way out?
Im using Step5 V7.23 under WinXP and didn't experience any problems with online communication to S5. Since version 7.2 of Step5 Siemens has changed access to COM port, so it should work with standard RS232 to TTY converter.
RAJATPALLAV said:
Dear ALL !!
What software are you using?
The old versions of Step 5 had COM1 hard coded as the communication port.
The story about the COM port you heard may have been someother application using com port #, such as Rslinx with DF1 driver, or some fax software.
Ian
Hi
We tried a converter ( usb ) , tried dual boot disk ( WinXP and Win 98 ) but best solution for us is a bootable USB stick .We shutdown and restart in dos using usb stick .The usb stick contains all DOS progreams we STILL HAVE to use .The dos version we are using is DR DOS
Eric
Online comms with S5 under XP require a "real" serial port with a 16450/16550 UART. USB adaptors don't have a real UART chip and - in my experience - don't work.
I'm regularly using S5 (V7.23) with XP using a PCMCIA serial card for online comms, Not sure if V7.1 will work but it has to be worth a go.
Nick
156
For the past few day, I have had problems accessing the Rockwell Knowledgebase. When I try to access it (and I do have a TechConnect Support...
401
Hi, Small issue i've really been beating myself up over today. I've been working with Panelview panels for years. Currently working on an older...
589
Dear experts, I have the following setup: CPU-313C (6ES7313-5BF03-0AB0 V2.6) + CP343-1 (6GK7343-1EX30-0XE0 V2.0) communicating with Siemens PC...
2,682
I'm looking to replace an AB PanelView 600 2711-K6C2 HMI with a C-more EA9-T10WCL. The PLC in the system is a SLC 5/03, which is staying. I...
1,244
