Yaskawa drive to Control Logix 5000
psycotic
Apr 2015
Modesto
Hi! I'm currently trying to implement my first AB Control Logix PLC program using Yaskawa P1000 drives (7 of them).. I haven't managed to make a connection to them yet, but I'm moving forward step by step. I'm using the SI-EN3 Ethernet/IP connection to the drives. My question today is:
I have them all setup as generic ethernet devices, using Input Assembly Instance 71, size 2 / and Output 21, size 2. This should give me tags I can manipulate for turning the drive on and off, and setting the speed reference. I need to know what the running current (amps) are. Looking at the specs on the yaskawa drive, it shows option F7-18 on the drive is for "Sets the scaling factor for the output current monitor in EtherNet/IP class ID 2AH Object.
How do I access the class ID 2AH Object? I see maybe I need to use a MSG command? But I couldn't see how to edit a MSG command to tell it what class and object I needed.
Obviously, I'm very new to Allen Bradley, and Ethernet/IP..I have used Ethernet/IP on an automation direct PLC with success. AB seems to be trickier.
Any advice would be MUCH appreciated!
Dave
Please look up for application note:
AN.AFD.22 from yaskawa.
Application Note:
Using Yaskawa's EtherNet/IP Options with ControlLogix and CompactLogix Controllers
Applicable Options(s): CM092, CM093, SI-EN3, SI-EN3/V
They explain exactly what you are looking for.
The EDS file is installed in the Logix file when you install the drive I the network tree.
take a few minutes look up using EDS files in Logix 5000 help it will explain it.
Hello. I installed 7 Yaskawa V1000 Drives along with the Yaskawa SI-EN3 comms cards. I was able to follow the steps from the Yaskawa web site when...
5,864
Hello, how are you? Sorry about what I have done to the USA, but it’s my wife fault she told me what to do! I am learning a new trade on the side...
6,864
Hi Everyone, I have a project involving a Beckhoff IPC with Twincat and a Yaskawa servo motor and drive. I'm trying to use the MC_HOME function...
496
I'm trying to set up a Yaskawa GA500 inverter to do multi- speed stage start up. I only want 3 stages. On run, ramp to 15HZ, wait n seconds to...
1,725
I figured out a solution to a vfd issue... at least in theory. Yaskawa has a program called Drive Works EZ that you can have PLC-type functions...
3,839
