By shut off, you mean powered down?
It might be possible that it powered up and was still jammed or in a bind somewhere. Or, it could be, that it was a one off event after powering up, a nuisance fault that may or may not happen again. I never worry too much until the 2nd occurrence...
Having it set the same probably means that you will see this software overcurrent fault in any overload condition before the normal motor ol fault you may expect.
It might be that the software current was set there intentionally. I don't remember what the book says about the default value.
You are basically setting the drive up to limit the motor to less than one second at FLA by having the value set the same. So it is a (kinda sorta) 9.9HP motor now...This can be a good thing, but it may have been a misunderstanding (easy one) by someone wanting to make sure they entered the FLA value where they thought it should be. I know by default, this feature is not enabled, you have to enter a value appropriate for instantaneous ( some short term average if I recall less than a half second).
When I used it, I always watched the amp reading under normal condition. I would trend it with drive explorer (or one of its older cousins) when I could, then make sure I set it well above the peak (like 150% or more). This was usually in reaction to a failure that ripped a belt or squished a bunch of goodies for a whole minute before faulting. So then, if something broke loose, it would fault first. We had it detect a split key in a long conveyor that was a really light load all except for about 5 degrees of its rotation when the mangled half key would snag the vacant groove in the pulley, they would reset it, the shaft would go one time around...spike at double my setting and shut down.
