Can new program, new main routine and new sub routine be made online
MattMatt9
Jun 2020
Canada
119
We have a project that has all the routines viewable but not editable. I just want to force a bit high but cant do it. The only way to do so is creating new task, and new main. There I can edit. So I guess they specifically locked out edits for the routines. My question is can I create a new program and new main routine all while online? Or does it have to be done offline and downloaded?
Based on the terms you are using I am guessing we are talking about the Allen-Bradley Logix 5000 product and either RSLogix 5000 or Studio 5000.
The controllers will allow you to create new programs and routines online and assign a routine as a main routine. Your software edition or security settings might limit this though. There is an edition called "Service Edition" that does not allow any online edits.
If you just need to set a bit, you can open the Controller or Program Tags and force (inputs and outputs) or set the value to a 1. Logic isn't required to do that.
OG
also just in case check if your PLC key or toggle switch is on "REM", if it is not move it to "REM" (remote run:handball:)
Hey fellas, Just curious. If I set up a GSV in my RSLogix 5000 main program for a ControlLogix processor to get last or max scan time, will the...
5,857
At work here I see a PLC 5 that has 3 MCPs in the status file. MCP A = 2, MCP B = 9, MCP C= 15. In the project tree in Lad 2 I see a MCP A...
4,835
i created a couple of "new programs" under the Main Task that i no longer want. when i right click on their names..."Delete" is greyed out. how do...
3,761
Hi, I am writing java code to read the Main sequence program from mitsubishi A series CPU namely A1SCPU. The default capacity of this program is...
9,079
Hi. I have a 222 CPU. I need to recover the program from the eeprom memory. Is it possible?
73
