Hello!!
I have a question for you guys, I understand that you can only enable one Message Instruction at a time. I had to use counters and timers to create a sequential order to make this work on the Modbus RS485 network channel,
But now we will need to add Modbus TCP. Therefore, we will be using a different comm port (ethernet TCP IP Port), Will these new MSG instruction need to follow the sequential order from the Modbus RS485 Network? Or, Since I’m using a different port to communicate, I don’t need to follow the existing Message instruction order ?
Thanks guys
Thanks guys
