As if I didn't have enough to do, I get hit with two more big projects.
First - Rebuild a transfer switch and install it with generator, shipped in from closed plant. So far, no problem. Thursday morning, supply purchasing with a list of parts, and give us a status report. And tell us if you will be using open or closed transition.
Second - Rebuild high pressure low volume pump and controls (2 speed motor?), also from closed plant. So far, no problem. Thursday morning, supply purchasing with a list of parts, and give us a status report. And tell us if you will be using open or closed transition.
I don't know where they came up with the open or closed transition. I don't have a clue. I did several searches, but didn't come up with anything I can use.
Can one of you out there help me?
Would the motor control and the transfer switch transitions be similar?
Doing the controls and transfer switch in the normal fashion should be fine, my guess is that this is open transition.
Help!
Del
Help!
Del
