Adding tags to existing logic 5000 controller
Robb B
Feb 2011
BC, Canuckistan
356
I tried exporting the database, adding my approximately 300 lines of tags, then importing it back, but I've clearly missed something in the formatting, numerous errors regarding discarding import. Any pointers? I added the necessary rows before the rung comments section, and pasted the list, adding COMMENT to the beginning of each new row, should it have been TAG instead?
Make a new tag in Logix that you need, then export.
Find the new tag in the export, delete all other rows (except for the firs ~ 7 header rows). Use the single row as the template for all new tags. Then you are only importing new stuff and should minimize further troubleshooting should you need it.
That would work, except I need to keep the existing tags intact. I tried doing like you describe, by finding known tags and copying their format. I think I've got it sorted out, except that the name portion irks with its limitations (no spaces, max characters etc). I have to basically rewrite the description into the name, but shorten it and underscore the spaces.
Hello everyone, Adding a remote rack of cards to control logix, I've added the cards to the controller through the enbt module, and it creates...
2,099
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
152
Hi PLCs.net! I'm using Studio5k V32, and I have an EDS file for the Fanuc 30r-ib plus controllers. I have an excel spreadsheet with bitwise...
1,439
I'm using a global DB as the i/o for some FBs (thank you, JesperMP). As I only need six bits for each FB I started with a byte as the input/output...
3,184
Hi all, I'm using Archestra SMC to manage tags in Wonderware Historian. I have an existing production line storing historical data, with maybe...
2,159
