To get a completely accurate answer, you need to know three things:
- The maximum flow rate through your flow meter
- The maximum scan time of your PLC
- The maximum input frequency of your hardware input
Once you work out your maximum flow rate, you can calculate how many pulses per second you will be getting on the input. Then you can calculate the time between pulses.
If the time between pulses is less than (or close to) your maximum PLC scantime, then you will need a high speed counter.
If the number of pulses per second is larger than (or close to) your maximum input frequency of your hardware input, then again, you will need a high speed counter.
If neither of those cases are true, then you do not need a high speed counter and can do it using normal counter logic in the PLC.
