Create a Siemens Update Server Locally
exiled
Jun 2002
England
131
Hi Gents. Hoping some of you have resolved this issue!
We have umpteen versions of Siemens TIA Software packages (& Other Legacy Software). Installed over various Laptop/Desktop/external SSDs etc.
We now have a huge issue connecting to the Siemens Update server since we have had some new World wide "Group" Anti Virus software/Firewall settings installed.
Is there a way I can download All the files to a hard drive then populate this location to all the others (essentially becoming a server address)?
if we need to set up a new server, it takes like 3 months as we have to go through so many hurdles
Could we just down load the files to a local ssd etc
exiled in the UK
You will get plenty of opinions here but
Have you gone to the Siemens support site and just downloaded what you need?
https://support.industry.siemens.com/cs/us/en/ps/dl
I've probably explained it poorly. Different pcs have different versions etc, some have the safety modules/licenses installed some don't.
I want to download all the files, then if the said pc is allowed then download the updates from said file/server
Perhaps the Tia administrator can be of use. I have not used it myself but my assumption is that it's for global management of Tia software but I might be wrong. Have you checked this out?
TIA Administrator
Different function modules can be incorporated in this web-based framework for administrative tasks for the TIA Portal. The basic package included here provides the functions for managing software and licenses including direct connection to the Online Software Delivery (OSD) services
Click the Help link in the Totally Integrated Automation Updater.
"Introduction
Using a corporate server, you can place selected updates / support packages on a local server and make them available to users, e.g. for different production lines. This has the advantage that users do not have to access the Internet, but can install updates via the intranet, an external hard disk, etc. Since users do not need direct access to the Internet, the protection against trojans or malicious software that contacts the Internet from the internal company network is significantly increased."
Hi, I have a HMI which is a KTP1200 Basic. Let's suppose USER03 is logged in. How do I create a simple "Lock Screen" that appears if the screen...
667
In my project, I've set up a few user accounts (Operator, Technician, Admin). The person assigned as Admin has said "I want to be able to...
1,134
See the attached image. The Datalog should be created when I press Report_Button_Pressed on the HMI. This image is taken when I pressed the...
1,077
Hey guys, The TL;DR is the last two paragraphs with a web link for you to try yourself. If you don't have anything better to do, look at the...
17,012
hi everybody I'm trying to create a Textfile in a USB pendrive connected to SIEMENS MP277, using a script in winCCflexible 2008. In the...
5,062
