A couple months, we started noticing that our RSView stations were failing to update. A simple fix at the time was to reset the EN2T/C module by pulling it out of the rack, and reinserting it. Eventually, we replaced the EN2T and upgraded our RSView stations to Windows 7 in hopes that we could alleviate the issue, but to no avail. Eventually, we noticed that it wasn't just RSView that was losing communication; anything that connected to that specific EN2T card was dropping the connection.
This led me to believe that we were having some sort of networking issue. Being that we have a rather expansive Ethernet network, I thought that there was a chance that some rogue device was flooding our network with garbage. To test this theory out, I setup port monitoring on the switch that the EN2T card was connected to, and setup a computer with Wireshark running in hopes that I could capture the event that was causing the comm losses.
Going through the Wireshark logs, I noticed a CIP connection failure around the time that comm loss had occurred. The error contained the following info:
Extended status: No buffer memory available (0x0301)
This message gets sent from the EN2T to any device that was connected to it.
After searching, I came across an article about increasing unconnected buffers in the processor. So I looked into it, and discovered that the L73 in question was already programmed to use the maximum of 40 unconnected buffers. The counters show that the high water mark is only 19 though.
So... My question is, what else could the issue be? I'm at a loss right now...
