plc storereviewsdownloads
Reply
Thread Tools Display Modes
Old March 13th, 2019, 02:09 PM   #1
Barbx
Brazil
Barbx is offline
Question HMI with Safe View - FTView SE
Hello all!
My customer asked for an HMI programmed with "Safe View" approach to avoid too many windows to be opened at the same time. He wants to allow only 4 screens maximum at any point of time and be configurable later.
I already put all displays to be replaced when opened, because I have a lot of pop-up possibilities to open faceplates and indicators in each one of them, so I totally don't know even how to start this... VBA or macro...
Thank you for reading!
ps: I'm using FactoryTalk View Studio CPR 9 SR 10, Local Station.
Old March 13th, 2019, 04:16 PM   #2
Ken Roach
United States
Ken Roach is offline
Ken Roach's Avatar
The most simple way to do this would be to have an HMI Tag for "Open_Windows".
Each Display has a "Startup Command" and a "Shutdown Command". You could make each one a Ramp Up or a Ramp Down of the Open_Windows tag.
Use the value of Open_Windows to animate the Visibility of each button that allows a window to open. FTView doesn't have an easy "Disable" feature (as far as I know) so I stack the visibility-animated button on top of a version that's just a grayed-out graphic/text of the button.
You'll probably also need some way to reset that open-number-of-windows value, and maybe also an indicator that says "Max # of Windows Are Open".
Old March 13th, 2019, 04:50 PM   #3
Ken Moore
United States
Ken Moore is offline
Ken Moore's Avatar
This is a built in feature for Some HIM packages, but not Rockwell.
Since you have the displays handled. You could index a counter, with each popup, and if the count =4 , close last popup, before opening next one. Not ideal because you would always close the 4th one opened. But you would never exceed 4.
__________________
https://azr.com/
Old March 14th, 2019, 04:01 PM   #4
Barbx
Brazil
Barbx is offline
First of all, thank you so much for helping.
I really liked both approaches, but I'm still kinda stuck.
I did a hybrid of them, and in my POV, maybe I'm making it more complicated but Allen-Bradley is not friendly user...
I did the "ramp "tag" +1/-1" in the commands/behavior in each page and the indicator like: "Open Windows: /*N:1 {Open_Windows} NOFILL DP:0*/ | Max: 4", but something was still missing. Then I linked a small logic on RSLogix5k to reset the counter when reaching the maximum, ok.
However, every time a display's button is clicked, it only calls the new display and the new display setting is to "replace" the other, but since the other was not "officially" shutdown, the counter tag doesn't receive the info, so it keeps always +1 in new principal displays. (I hope I'm being clear enough) ):
To avoid open one new display every time, in these buttons, the press action is "Display x" and in the release is "Abort Me" or only "Abort", but when it's in this "Display x" is active, it would abort himself since I'm using global objects.
It's still in testing...
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
FTView SE HMI Tag Alarm phuz LIVE PLC Questions And Answers 0 October 24th, 2018 01:28 PM
Not able to see the SE application in View point Nelliyan LIVE PLC Questions And Answers 1 May 11th, 2016 11:15 PM
FactoryTalk View SE view 3 panel views in one computer? sdanielracing LIVE PLC Questions And Answers 3 January 26th, 2015 04:57 AM
FTView SE and Tablet PC Input Service mlmeng16 LIVE PLC Questions And Answers 1 January 15th, 2013 01:05 PM
Factory Talk View SE failed to open HMI project icanmaul LIVE PLC Questions And Answers 0 September 3rd, 2012 12:37 AM
