Rite Hite over head door
jimcav
Dec 2004
new jersey
229
Good Morning
I have been given the task of making a new control panel for one of our rite hite door controllers. It uses an Omron plc I dont have the software to extract the program. I was wondering if anyone has done this before. The operation seems straight forward but there might be something I did not think about, even just a PDF to look at would be good. I will also take any advice. I know its a door that goes up and down but I value what is said here it will be worth considering when i start writing a new program.
Jim Cav
RiteHites I dealt with over a year ago were Mitsubishi PLCs. the initial one was labeled with RiteHite but I had to have it replaced as the power failures that place experienced finally burned it, the replacement came in, dead same PLC but had Mitsubishi emblazoned upon it. Almost custom fit to that job, had no spare IO contacts.
Hi everyone, I hope you're all doing well. I'm currently working on updating an HMI project for the GP2500, and I've encountered a bit of a...
55
I've gotten to the learning curve where I can program a call for pump to come on at set point but I'm not sure how to turn the same pump off when...
119
Hi everyone, I am working on a project that needs to expose the SV (Set Value) of a temperature controller to a SCADA system. SCADA <-...
153
Thank you for any and all responses/help. I have an RSLogix 5000 v20 and a Cognex In-Sight v5.9 spreadsheet (8502P). I can not figure out how to...
118
Hello, This is my first exposure to CCW Micro8xx family. Someone will write to my existing micro850. Modbus TCP is turned on and I created a...
166
