plc storereviewsdownloads
PLC training tools sale
Reply
Thread Tools Display Modes
Old January 21st, 2009, 10:36 AM   #1
tacm
United States
tacm is offline
tacm's Avatar
Momentary output energize rs 500
I have a problem with a line of code I am trying. I have an output i need to energize for two seconds and then drop out, although the input that is associated with the output will remain true. I was able to acive this with the code I wrote, however on the next scan the output went high again. I am sure there is a simple way to do this, however everything I have come up with is complcated. I am using RSlogix 500 with a micrologix 1000. Any ideas would be great. I am sorry, I cannot post the code I have written so far as I am not at the office.
Thanx
__________________
"The sole end for which mankind are warranted, individually or collectively, in interfering with the liberty of action of any of their number, is self-protection. That the only purpose for which power can be rightfully exercised over any member of a civilized community, against his will, is to prevent harm to others. His own good, either physical or moral, is not a sufficient warrant." John Stuart Mill
Old January 21st, 2009, 10:43 AM   #2
bernie_carlton
United States
bernie_carlton is offline
bernie_carlton's Avatar
In RSLogix, double click on the rung number for this rung. The line of mnemonics will pop up. Please cut and paste this line into a post so that we can look at the code.
__________________
Controlling outputs is the PLC's way of getting its inputs to change.
www.thePLCguy.com
Old January 21st, 2009, 10:53 AM   #3
tacm
United States
tacm is offline
tacm's Avatar
Quote:
Thanx
Thank you but I cannot right now, hovever this has been bothering me since yesterday afternoon.
__________________
Old January 21st, 2009, 11:21 AM   #4
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
In my example, no matter how long B10/11 is true, B10/10 will only be energized for 2.5 seconds.
Hope this helps,
Paul
__________________
It's not all the variables I am most concerned with, it's the undiscovered constants.
Old January 21st, 2009, 11:43 AM   #5
tacm
United States
tacm is offline
tacm's Avatar
Quote:
Hope this helps,
Paul
Paul, you are not using a (res) you are relying on the true false rung transision of B10/11 to reset the TON?
__________________
Old January 21st, 2009, 11:50 AM   #6
OkiePC
United States
OkiePC is offline
OkiePC's Avatar
Yes.
If you RESet the timer, and the timer rung is still true, then the TT bit will again go true for 2.5 seconds.
__________________
Old January 21st, 2009, 12:11 PM   #7
tacm
United States
tacm is offline
tacm's Avatar
rung 1 XIC I:0.0/1 XIO I:0.0/2 TON T4:1 1.0 1 0
rung 2 XIC T4:1/TT OTE O:0.0/0
If XIC I:0.0/1 stays true and XIO I:0.0/2 toggles the timer will reset. yes?
__________________
Old January 21st, 2009, 12:13 PM   #8
tacm
United States
tacm is offline
tacm's Avatar
I feel like my avatar today.........my house was broken into last night, and I only got a 1/2 hour of sleep
__________________
Old January 21st, 2009, 12:51 PM   #9
OZEE
United States
OZEE is offline
Yes -- if EITHER I:0/1 or I:0/2 toggles, the timer will reset.
Old August 17th, 2016, 12:53 PM   #10
Flower8
Andorra
Flower8 is offline
xoxo
Hello! If you want an exceptional essay able to impress everyone, I believe you should visit this source where you can get any essay you'd like on any topic, follow http://bigpaperwriter.com/blog/john-...say-on-liberty
Old August 17th, 2016, 04:01 PM   #11
James Mcquade
United States
James Mcquade is offline
why not use 2 rungs.
rung 1 input turns on, then a one shot and then a tof timer set for your required time.
rung 2 timer dn bit turns on output
as long as the input stays on, the timer will only work once.
regards,
james
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Rockwell Allen Bradley Programming Software, RSLogix 5, RSLogix 500, RS Linx, RSLogix vvcd LIVE PLC Questions And Answers 21 September 24th, 2009 11:04 PM
Programming in RS Logix 500 AB2005 LIVE PLC Questions And Answers 9 September 25th, 2008 10:05 AM
linux and rs logix 500 mdavis33513 LIVE PLC Questions And Answers 5 September 22nd, 2008 02:11 AM
RS Logix 500 randy LIVE PLC Questions And Answers 14 January 23rd, 2003 08:12 PM
Please help RS logix 500 Activation Key Problem labingtone LIVE PLC Questions And Answers 9 November 26th, 2002 09:27 PM
