AdvancedHMI Modbustcp problems with RS-485 network
p8t4
Aug 2012
Spain
Hello to all the forum, I'm trying to run the Arduino UNO with AdvancedHMI with modbus library does not work, I'm using a ModbusTCP server and with other software like mango m2m or ScadaBR that works very well.The use of 485 to ModbusTCP is Moxa nport5130.
I put some pictures of the configurations and arduino code, the errors also gives me the AdvancedHMI.
Arduino basic scheme with MAX485:
Converter RS485--->ModbusTcp--->IP:192.168.1.64/Port:4001
Configuration MosbusTcp in ScadaBR:
Points details and adress in ScadaBR:
Running on Scadabr with ModbusTCP protocol:
Configuration ModbusTcpCom1 in AdvancedHMI:
Configuration Digitalpanelmeter in AdvancedHMI:
AdvancedHMI error adress 30000:
AdvancedHMI error adress 30001:
Finally hit arduino code I am using and referring to the library used:
Code:
#include <ModbusSlave.h>
*  ModBus Slave Library *Example*
*  By André Sarmento Barbosa
*  [email protected]
*  Check whole project at:
*  http://www.diybrasil.com.br/projetos/rede-de-automaacaao-rs-485modbus-com-arduino
*  History:
*  I had modified original library Arduino Modbus Slave:
*  http://sites.google.com/site/jpmzometa/arduino-mbrt/arduino-modbus-slave
*  adding:
*  - Function 0x01 - Read Coils
*  - Function 0x02 - Read Input Status
*  - Function 0x04 - Read Input Registers
*  - Function 0x05 - Write Single Coil
*  - New methods for setup arrays of holding registers, input registers, coils and discrete inputs.
*  - Arduino 0.22 and 1.0 support
*  I did this example to test the new library and show integration with ScadaBR software:
*  http://www.sacadabr.com.br
/* First step MBS: create an instance */
ModbusSlave mbs;
/* slave holding registers - int (read/write) */
enum {
        MB_CTRL,        /* Led control on, off or blink */
        MB_CTRL1,       /* Control Ventilador (Fan) */
        MB_TIME,        /* blink time in milliseconds */
        MB_CNT,         /* count the number of blinks */
        MB_REGS         /* total number of holding registers on slave */
/* slave input registers - int (read only) */
enum {
        MB_REG0,        /* Potenciometro 0 al analog 0 */
        MB_REG1,        /* Lectura de voltaje 0-15 con divisor de tensión al analog 1 */
        MB_REG2,        /* Lectura de intensidad efecto hall al analog 2 */
        MB_INPUTREGS    /* total number of input registers on slave */
float voltaje=0;
int analogInPin = A2; // Analog input pin that the carrier board OUT is connected to
float sensorValue = 0; // value read from the carrier board
float outputValue = 0; // output in milliamps
int regs[MB_REGS];
int inputregs[MB_INPUTREGS];
int ledPin13 = 13;
int Ventilador = 4;
unsigned long wdog = 0;         /* watchdog */
unsigned long tprev = 0;         /* previous time*/
void setup()
/* the Modbus slave configuration parameters */
  const unsigned char SLAVE = 1;      /* slaveId */
  const long BAUD = 9600;             /* baud rate */
  const char PARITY = 'n';             /* n=none; e=even; o=odd */
  const char TXENPIN = 2;              /* output driver enable pin */
  /* Second step MBS: configure */
  mbs.configure(SLAVE, BAUD, PARITY, TXENPIN);
  mbs.setup_regs(regs, MB_REGS);
  mbs.setup_inputregs(inputregs, MB_INPUTREGS);
  pinMode(ledPin13, OUTPUT);
  pinMode(Ventilador, OUTPUT);
void loop()
        /* Third and las step MBS: update in loop*/
        if(mbs.update())
                wdog = millis();
                voltaje = map(analogRead(A1), 0, 1023, 0, 15000);
        // read the analog in value:
                sensorValue = analogRead(analogInPin)-512;
        // convert to milli amps
                outputValue = ( ((long)sensorValue * 5000 / 1024) ) * 1000 / 66;
        if ((millis() - wdog) > 1000)
            inputregs[MB_REG0] = analogRead(A0); /* lectura potenciometro A0 */
            inputregs[MB_REG1] = voltaje; /* lectura voltaje 0-15v A1 */
            inputregs[MB_REG2] = outputValue; /* lectura intensidad efecto hall A2 */
             if (regs[MB_CTRL] == 0)
                    digitalWrite(ledPin13, LOW);
             if (regs[MB_CTRL] == 1)
                    digitalWrite(ledPin13, HIGH);
             if (regs[MB_CTRL1] == 0)
                    digitalWrite(Ventilador, LOW);
             if (regs[MB_CTRL1] == 1)
                    digitalWrite(Ventilador, HIGH);
The problem is I have no communication with AdvancedHMI, 've tried different values​​,40000,400001,400002 etc ... and nothing.Me and would love to run this with AdvancedHMI, because I think a powerful software.
Thank you and sorry for my English.
No one knows? any idea why it does not work AdvancedHMI with arduino?
I think it should work.
Greetings from Spain.
I can't see serial side network settings (Frame mode,parity,stopbit) in both device and Serial converter.
I would like to temporarily install AdvancedHMI on the same computer as FactoryTalk View SE. I am waiting for another contractor to finish the FTV...
556
Hi all, just wanna ask if anyone has used an M221 controller and successfully connected to AdvancedHMI
1,314
MessageDisplayByValue question is there a way to embed a tag value in the messages of the MessageDisplayByValue function ??? Similar to what is...
2,818
Hi All I have been switching between 2017 and 2019, all depending on which one i found more stable, at the moment I use 2019 I was just...
1,478
I tried to use AdvancedHMI as a Modubius Client and it does poll the data from a Modbus server. But I am unable to use AdvancedHMI as a server...
3,048
