Redlion Crimson 3 - How do to a simple image replace animation?
gbeaker
Sep 2012
earth
148
I've got a few images I want to play together in series to make an animation. I've got the frames already setup as in a single image object, but what can I use as a good time base for swapping the images? I think 100ms is a good rate, but GetNowTime() only returns the whole seconds. Should I just use a value from the plc instead?
How good is the "animation" you get using DspCount to trigger the animation steps ?
I've never been able to get 'smooth' animation in Crimson changing the image more than about 4 times per second.
On the bench, The Fan looks perfect, a lot better than it looked when I tried using a timer.
I haven't tried it in the field, where other factors may come into play.
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
124
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
169
It states WinPcap must be installed for the Emulator to function. WinPcap.org states that the technology is mature with no updates planned. Am I...
859
Following on from another thread, I just downloaded Crimson 3.2 and it now supports CR and Graphite HMIs. Time for a 'play' :-) It seems to have...
2,023
Action On Release command Set(ConveyorPopup,ConveyorPop_1) rejected w/ string tags. SetStringTag(index, data) wants an index. How does one pass...
959
