wildswing
I have 3 CNet nodes, all 1734 Point IO. First contains mix of 16 IE8C analog and 6 IB8 discrete in, second is mix of 12 OE4C analog and 4 OB8 digital out, 3rd is oem configured discrete out air valve block using 6 generic modules.
After I schedule the network in RSNetWorx all the yellow warnings go away in RSL5000. All seems fine. When I save the project RSL5000 gives me 28 warnings saying the analog modules are not scheduled.
I found this while searching the Rockwell tech site:
http://rockwellautomation.custhelp.com/app/answers/detail/a_id/33777
I've sent Rockwell Tech a message through my eConnect, but they seem to be taking their sweet time getting back to me.
I'm continuing with the project while I wait for their reply. Everything seems ok except for this warning every time I save the project. Anyone else run into this?
After saving, I can come back online and all is well again. No need to reschedule. I'm running this with RSL5000 v16 in an v16.2 L55.When doing a file save in RSLogix 5000 after scheduling a ControlNet network you may receive the error "Warning: ControlNet connection not scheduled." There is a problem in RSLogix 5000 and this should be fixed in a future release of RSLogix 5000. Scheduling from RSLogix should still schedule the network, but after the file is saved and redownload, the 1734-ACNR will no longer be scheduled.
The Work Around for this is to delete the RSNetworx file association from RSLogix 5000 before the project is saved.
Problem: There is a problem with RSLogix 5000 when associating an RSNetworx for ControlNet file.
Cause:
Verify:
Cure: Will be fixed in version 15.26
Prevention: The Work Around for this is to delete the RSNetworx file association from RSLogix 5000 before the project is saved.
