Omron
JohnHenry
Mar 2018
Setubal
Programing noob here. I have a CJ2M CPU31 and i need to read and scale the signals from and arduino in either serial or BCD. (Since PWM proved quite impossible for me)
I was wondering if anyone could help me out with that, and how do I program a scale that can receive the signals and turn it into a 0-100% scale.
yep PWM, is not the way to do this, as the PLC is way too slow for thsi to get it good.
yes you can use a serial connection, (with an UNO you will need a extra serial pinning like softwareserial. on a MEGA there are 3 serial, is easier to do and still pretty cheap.
you can also use the ethernet to communicate.
a simple way to do this is to use a slow I2C connection, please take care of the 24 Volt to 5 Volt.
Good morning everyone I’m currently working on a omron device net and have a nord drive that fell off the network. I have limit knowledge in...
88
I've come across a system running omeron cx-programmer version 9.42. Am I going to need to find a legacy version of the software to edit and...
78
Has anyone done SMS messaging from an Omron CJ2J-CPU31 PLC? If so could you help please. Omron here in Oz have not had any experience doing this...
212
I have an old plc in the system I have, moxa nport was used to communicate with scada, I want to replace the plc with cj2m cpu33 and eliminate...
86
Hi all, i have 8 CJ2m plc units that show different numbers on the plc display and i am stuck on reading the info. my unit has an ip address of...
147
