brian1 Member B Join Date Feb 2004 Posts 6 Aug 14, 2006 #1 I just got an XP machine and I would like to install RSLOGIX on it but I'm not sure I can. It installed just fine on my 2000 machine but not having much luck with XP.
TimWilborne Lifetime Supporting Member Join Date Oct 2005 Location Roanoke, VA Posts 2,210 Aug 14, 2006 #2 What version of RsLogix? We talking 5, 500, or 5000?
rsdoran Lifetime Supporting Member Join Date Apr 2002 Location Birmingham, AL Posts 7,371 Aug 15, 2006 #3 Brian's other posts refered to an SLC so I will assume that it is RSL500, if so then it needs to be version 5.20.00 or higher to install on XP. If it gives you some error talking about WinNT then you have version 5.00.00 more than likely.
Kevbo Member K Join Date Aug 2006 Location Albuquerque,NM Posts 27 Aug 15, 2006 #5 XP-pro, (vs. home edition) may be required. Big issue, as most laptops nominally are bundled with HE.
Operaghost Member Join Date Apr 2002 Location Dallas, TX USA Posts 4,086 Aug 15, 2006 #7 <.....searching for thumb screws> What exactly does "not having much luck" mean? When is the error occuring and what error or problem are you seeing? XP and RSLogix play together just fine, but we need to know what isn't working. OG
brian1 Member OP B Join Date Feb 2004 Posts 6 Aug 15, 2006 #8 I de-fragged my HD and the process went very smoothly. Thanks everybody!!
Operaghost Member Join Date Apr 2002 Location Dallas, TX USA Posts 4,086 Aug 15, 2006 #9 Ah, the defrag placebo. Cures all ills! OG
