RS View 32 - MicroLogix 1500 - ENI Module
bmtrash
Dec 2003
Fort Wayne, IN
I am trying to communicate between a Micrologix 1500 w/ ENI module and RS view 32. I keep having trouble establishing a connections. I should have checked before but is there any prior know conflicts with this type of hardware setup? Are there any special settings that need to be configured? Any help/advice is greatly appreaciated.
Also, when i run the RS veiw 32 demo and get dummy information back in the DBF format, there are extra columns added into the file when i open it in Excel. They all look like status bits columns, can i get rid of them with a setup or settings change?
Thanks for the help,
Bryan
1. I have a number of 1500 with ENI connected to RSView32. What version of RSLinx are you running?
FYI RSView will not run with RSLinx Lite.
2. I have never tried but I don't think delet those extra columns. How do you log, Long or Narrow format?
Bob
I was using Rslinx lite 2.3.1. I heard that you could not use lite with Rsview 32, so I switched to Rslinx pro demo last night. That solved some problems but i still can not connect to the PLC correctly. Tomorrow i will post some of the error codes that i recieve when i am trying to initiate communication.
Right now i am logging in long format, this is not set in stone though.
Thanks for the leads,
Bryan
79
Hello, Well, after fighting thru comm and cable issues from pc to panelview and pc to plc finally communicating with each separately. I have...
20
17,850
Hello All: I have recently been tasked to add a touch screen to a piece of equipment on the floor. Now the equipment uses a micrologix 1500...
4,277
Hey guys! I need to communicate a PV550 with a Micrologix 1500 ASAP, but the 1761-NET-AIC doesn't seem to be working. I was wondering if the...
5,233
So I figured I'd start off by saying I love this place. I never registered, but frequent this place often to read up on the little tricks to get...
3,345
