Hi guys,
I have a question about a sequencing program I am trying to make work. What I have is an baking oven conveyor with various equipment on the infeed such as a pan greaser, depositor, etc. The sequencing programming I have works but needs improvement. The conveyor has pan carriers every 20", a encoder to measure this distance and a pan sensor to sense if pans are in the carriers. The way I have it programmed now is with a bit shift instruction in which if there is a pan present in the carrier it inserts a 1 and no pan inserts a 0. My problem is that some of my infeed equipment is not placed at exactly 20" so I run into the problem of not being able to adjust for this. In other words I may be 1/2 a pan out where my depsotior is supposed to start. I can't move the equipment so my idea is to break the pan up into more bits in the bit shift so that I can adjust my start point. I am having trouble working out how to do this. Does anyone have experience with something like this? Also I am using the shift register bit that says a pan is present to either turn and keep my trigger on or off depending on whether there is a pan present. If I do this I would have to come up with a way to keep this bit turned on for the time the pan is under the piece of equipment because using a later bit in the word would also mean that it would turn off sooner than needed. BTW this is a AB PLC5. Any help would be appreciated.
