Does anyone have experience using the Position Indexer Feature with a powerflex 700 drive. Below is what we are trying to accomplish.
We have an existing mechanical walking beam system that is driven by a hydraulic motor. Each time the machine cycles the hydraulic motor drives the transfer table through one full rotation (360°). The hydraulic motor and control valve are now obsolete so we ordered the new drive system that the OEM recommends which consists of an Electric AC motor coupled to a gearbox, however the OEM will not include controls, therefore we are doing the controls ourselves.
We are planning to use a powerflex 700 to control the motor with an encoder on the transfer table to measure position. My question is this.
Should I attempt to use the postion indexer function built into the drive or would I be better off doing the control with a ControlLogix with a motion module and the motion instructions built into RSLogix.
Precise position control is not required. I just need a relatively smooth accel and decel and it needs to stop near home position each cycle.
