Powerflex 40 drive suddnly stopping while running & there is no alarm on the display
sahebanna
Nov 2009
Bangalore
I need help on Powerflex 40,
3 no's powerflex drives are connected to compact logix plc on ethernet network, PLC will send all commands (start, speeed) to drive on ethernet network. problem is in one of the powerflex drive remaining two drives are runnning while running the drive, suddnly drive will go to stop mode eventhough start command enabled from the PLC and it will not generate any alarm on the display. if we stop the complete system and started, drive start running after some time again it going to stop mode (Drive start LED on the powerflex 40 go off). i compared all parameters (except motor related) with refference to running drive, there is no change.please explain me what is the problem with drive and what are the parameters i need to check.
t
is it possible to swap the problem drive with one of the other two to see if the problem follows the drive, if it does I would suspect the drive. If the problem stays where it is then it's probably a comms problem.
Steve
Dear We are working in AB Studio 5000 and the drive is a PowerFlex 755T. For this project I need to control a conveyor to a certain set point...
138
I have a client who's Powerflex 755 VFD has one of its inverter cards failed. the card is with the model number SK-R1-IG1-C770D740. Does anyone...
259
Is it possible to set IP address of Powerflex drive, without powering up the entire 3 phase circuit? Is there some way to just power up the keypad...
705
Hello, I have a machine with 4 powerflex 4m drives that are networked using a 22-XCOMM-DC-BASE with a 22-comm-e card attached. Backstory....There...
462
Hey all, I wanted to discuss an issue with achieving a constant flow rate of around 10 GPM on a glycol circulation pumps in a 1200-1300 PSI...
937
