start picture not found WINCC
behnamelfy
Nov 2014
Iran
19
Dear colleagues
I am trying to load a project from the multi-project in wincc.
I will tell you about the procedure that I've done
I've created a multi-project in server side
of course, I can ping the IPs in the both client and sever sides.
then I created a simple project in the graphic designer
after that, I created the client in the computer part of the wincc and selected the page that I created before as the start picture.
in the next step, I created the server in the serverdata and configured it
then I shared the project with full access
on the client side I created the client project but when I want to load the server package in the serverdata there is not any package which is weird
I tried to open the project in the client but again the same problem
I searched on the internet and followed all the advice from this
https://support.industry.siemens.co...nd-start-picture/4900/?page=0&pageSize=10#top
but could not get a reasonable answer. I also created the project again and followed the procedure several times but I could not succeed in loading the project in the client.
I am looking forward to a solution to this problem
Thanks and Regards
Hi All I am busy with a project where additions are to be made to an existing WinCC v 7.2 Single user project. I managed to get the project...
2,156
How to fix if appears code “$115 plc-restart running” on the screen OP17
246
Hello everyone, I'm new here. First of all I just want to say that you guys are very knowledgeable and reading your posts on here has saved my...
161
can anyone has a good program to learn plc programming online. i have the basic looking into improve my skills thanks
144
Hi guys! I'm working in Studio 5000 and have a bunch of armorstarts there (+- 40). I need to set up parameters for each of them, mostly just same...
90
