1756-BA2 in SLC 5/04?
jrsnydley
Dec 2014
Minnesota
155
This may be a dumb question but can I use a 1756-BA2 in place of the 1747-BA for a SLC 5/04? The reason I ask is that we stock the 1756-BA2 in our spare parts.
No the connection is different from the BA2 to the BA, see the details of the ones we sell below... they are also cheap and small enough to stock the correct one
1747-BA
Type: Lithium
Voltage: 3.0
Capacity: 1200 mAh
Color: Black Heat Shrink
Size: 0.58" diameter x 1.04" long
1756-BA2
Type: Lithium
Voltage: 3.0
Capacity: 1200 mAh
Size: 0.68" dia. x 1.38" tall
1756-BA1
Type: Lithium
Voltage: 3.0
Capacity: 1800 mAh
The BA1 has the same connection but the size is not the same and will have a hard time fitting in the holder
Yeah, I thought the connection was the same but I guess not. There can't be any sort of standardization, that would make things too simple.
How has your experience been using non-Allen Bradley 1756-BA2 batteries? Would you use them in all instances, or limited applications? Any other...
16
5,103
Good Afternoon , We have a ControlLogix 5561 controller. The maintenance group , powered down the machine and lost the program. The battery...
5,183
Is there any difference between these batteries other than the connector style? We have a ControlLogix L61 processor with a dead 1756-BA2 battery...
14,401
Hey Guys, I thought I knew the answer to this, but after some looking I am starting to doubt myself. I thought the 1756-EN2TR would allow you to...
93
We had a site where a rat gnawed through some fiber optic cables which (obviously) prevented communication to a remote rack entirely. We, and the...
112
