Schneider M241 communication with Magelis HMI STU885
HamzaSA
Aug 2017
Sarajevo
34
Hello,
I am making a simple temperature measurement so I can configure my PLC and HMI together. I want the value measured by the sensor connected to the PLC to be visualized on the HMI.
I'm having problems with making my M241 communicate with Magelis HMI. PLC configuration is ok, and I have managed to download the HMI configuration to the HMI.
I have also linked the variables from M241 to HMi via "Symbol configuration" -> Generate Code for the .xml file -> selecting the .xml when prompted by the "Variables - Link Variables" tab in HMI.
However, I can't get the values to visualise on the HMI, neither the physical one nor the virtual HMI with the Visualize command.
Any suggestions?
Thanks,
Tarik
Hey, I forgot about this post in the meantime. I managed to solve the issue, the problem was a cable malfunction.
I have an M241 connected in Ethernet to a HMIS5T panel and I can't get them to communicate I'm using Machine Expert 1.2 On the controller the...
1,790
Hello friends, I need help regarding Modbus protocol when dealing with multiple slaves. Even though I am new to Modbus, I have read the...
20
11,493
Hello, As part of our project, we are using an M241 controller. This controller interfaces with an industrial computer and a router via a switch...
60
Hello, Recently I was asked to analyze the logic of the air conditioning system in one of our departments. The PLC that controls this system is...
144
I have a machine that has M241 PLC. I need to add a couple of outputs to the program, and I don't have the original code. Am I screwed or can I...
460
