alive15
Good afternoon,
I am using A.B. L27ERM-QBFC1B with v.30.11 on it. I have a Keyence SR-1000W Barcode scanner. I'm scanning a Datamatrix bar code and these characters come into the PLC in decimal format. However, I need to read these in Ascii format.
I'm also checking the length of the ascii characters as well, not the decimal. However, I am having difficulty converting into a readable ascii character. I can manually change the tag from decimal to ascii, but this does not change the tag value coming in, it only changes the appearance of it.
I tried DTOS, but the decimal character format remains. See picture. The # reads 926365748, but I need it to read in ascii "7784" as seen in the pictures attached.
Thanks!
Thanks!
