Redlion Webserver capability SQL connection query report
scaleman74
Jun 2018
Leeds
Goodevening all...
I have a Redlion PTV and Graphite with built in webserver...
I can create the simple default.htm page... drag in tags to display data etc...
is it possible to build and host a web form html page that I can connect to an SQL (express db) and have some controls on the page for example, start date, end date, filter by... batch code etc etc...
not getting anything from Redlion UK support of any worth while examples... or even a yes or no...
any help appreciated...
Hopefully someone with more knowledge will chip in, but here are my low end thoughts.
The Crimson 3.1 manual has a chapter on connecting to an SQL database and grabbing data, page 221:
http://www.redlion.cn/sites/default/files/Crimson 3.1 Manual English (Revision 2) 12MB.pdf
Here is a tech note on making a connection to an SQL database:
http://www.redlion.net/sites/defaul...310 and G315 - SQL Synchronization TNIA28.pdf
This shows you how to create web pages and include tag data:
https://www.youtube.com/watch?v=4yYqTmSt0xc
So all that says you can get data from an SQL database in to tags on the HMI, and you can display the tags on an internal web page. So I think, 'computer says yes'.
I have a a Red Lion G12 Graphite HMI connected to a L32E compactlogix. The System has a 3G mobile modem to enable remote login. The mobile...
1,551
Hey guys, hoping someone here could give me a little advice. I'm working with a CR1000-04000 in Crimson 3.1 and I was interested in adding the...
114
Hi, I have a complex database in Crimson 3.0 and in one of the display pages I am trying to get a tag to show the sum of several other tags. The...
160
Hi All, Hoping to get some insight into best way to terminate shielded twisted pair + common into a RJ45 required for RedLion RS485...
216
I have 8 of these systems all running the same code. Just this one seem to gain about 30 seconds in time everyday. So in 48hrs time will be...
652
