Schneider (Modicon) Arrays using structures as data types
Aug 2015
Michigan
Somewhat new to Schneider (aka Modicon) PLC's and the Unity Pro XL programming software. I have a TSX P57 6634M PLC. I would like to take an existing solution created for a Rockwell StudioLogix application and translate it without having to do too much total rewrite.
I've hit a roadblock however and hoping to find a reasonable solution. I am using arrays that are using data type Structure which are made up of a mix of DINTs and other structures. What I would like to do is to be able to query the Length of the array similar to how the SIZE command in Rockwell returns a value for the array length. The SIZE command can handle arrays of UDT's as well as the elementary data types such as INT, DINT, etc. I found the LENGTH array instruction in the Unity Pro library but it looks like it is only capable of working on elementary data types. Does anyone know of a work-around or if there is a different approach to achieve the same result?
I realized I should be clearer in my description when I mentioned arrays using data type of "structure". For Unity Pro it is more proper to use the term DDT - Derived Data Type. Hope this helps clarify what I originally posted.
The function 'SIZEOF' gives the length of a variable in bytes.
The variable can be any type eg an array of structures
Hope this helps
Also have a look at the 'EXTRACT' function it may also be useful.
I have an old PLC (circa 2007) consisting of Telemecanique/Modicon/Schneider Electric devices. The system has developed errors and unfortunately...
177
Hey all, I do not have the original source code of a Modicon M172 PLC (HVAC PLC). I want to modify some of the code but read you cant upload...
283
Hi, I have an older Kohler Generator/ATS controller that has a Schneider Electric (Modicon) Momentum PLC and has a Advantech HMI. I assume this...
677
Hello, I'm having a hard time understanding how to get a Modicon M340 to pull a Modbus address from an ABB Totalflow via Ethernet. I set up a port...
1,105
Hi, I'm configuring the M340 controller with ATV320 inverters via Canopen. Everything was fine until today, when after starting the electrical...
1,282
