grnick50
Hello all,
Can someone who uses Ignition, advise me on how to setup a multiple display Project.
I have two build the project using a single client lisence and two 1920x1080 monitors.
I sort of managed to do it but I am not realy happy with my solution.
I 've setup the project to windows mode 3840x1080. I have set it up so that it launches windowed.
I then did my windows having a resolution of 3840x1080. It looks ok but the problems is that when I maximise the project shrinks to one monitor only. I can basically run in the project in both monitors only when the SCADA window is not maximized and the window is floating.
Any suggestions? I did not seem to find any usable solutions in the manuals.
Regards
Regards
